1 - 9 of 9 Posts
Great I'll go ahead and order. Also, I need 2l of v160 oil and I'm curious if it's all shipped from the same place? Reason being is I don't want any that's been sitting for ages and I figure you guys probably sel the most. Thanks
Need a quote for the shifter linkage, everything except the rubber boot so the rod, pin, clip, bolt, 2 washers, and nut. Also, I need the gasket that sits between the plastic piece on the shifter and the tripod. It's a circular gasket with a square cut out. This was not included with my shifter assembly and I don't imagine it would come with the tripod either.
Anime Dork
90250-06026 pin, stra list 1.90 cost 1.42
90467-21010 clip list 3.48 cost 2.61
33511-14031 shaft, co list 41.37 cost 31.03
90387-08134 collar list 3.39 cost 2.54
90301-11015 ring, o list 4.88 cost 3.66 x2
90105-08200 bolt, was list 1.67 cost 1.25
90179-08095 nut list 1.72 cost 1.29
33513-22030 yoke, con list 12.58 cost 9.43
33057-14010 bracket s list 73.55 cost 55.16
91651-60835 bolt, w/w list 2.13 cost 1.60 x2
1 - 9 of 9 Posts
