1 - 2 of 2 Posts
15100-46052 OIL PUMP LIST 226.67 COST 170.00
04111-46094 FULL GASKET KIT LIST 480.77 COST 365.00
[includes valve stem seals and everything else you'll need]
00295-00103 FIPG PAN SEALER LIST 13.82 COST 10.44 EA X 3
90915-YZZD3 OIL FILTER V8 USA LIST 5.41 COST 3.96
00272-1LLAC-01 ANTIFREEZE RED LIST 25.39 COST 19.38 EA X 2
15710-46020 OIL COOLER LIST 610.64 COST 465.00
[MANDATORY IF YOUR MOTOR HAD ANY INTERNAL DAMAGE]
15670-46070 BRACKET OIL FILTER LIST 96.20 COST 73.44 [ FROM NA MODEL TO ELIMINATE STOCK TT OIL COOLER IF YOUR GOING TO USE AN AFTERMARKET ONE]
16100-49846 WATERPUMP LIST 166.70 COST 125.00
13505-46041 T/BELT IDLER LIST 88.14 COST 67.30
13568-49036 T/BELT LIST 34.68 COST 26.43
13540-46030 T/BELT TENSIONER LIST 74.94 COST 57.21
13011-46051 TT RING SET LIST 237.55 COST 180.00 [ std only]
13101-46091 TT PISTON LIST 80.34 COST 60.00 EA X 6 [ std only]
13201-46040 TT CONNECTION ROD LIST 88.63 COST 65.00 EA X 6
13041-46013-XX ROD BEARINGS LIST 15.67 COST 11.96 EA X 6
11071-46020-XX MAIN BEARING #1 LIST 25.83 COST 19.72
11701-46020-XX MAIN BEARING #2-#7 LIST 27.90 COST 21.30 EA X 6
11011-46030 THRUST WASHER SET LIST 40.95 COST 31.27
1 - 2 of 2 Posts
