1 - 2 of 2 Posts
Hi all,
I'm looking to ditch my auto box in MK4 and drop in a late spec r154 out of a JZX100.
What are my options in regards to the propshaft?
Am I right in saying the jzx100 is front prop too long? And would the front prop for z30 r154 fit the jzx100 r154?
Thanks for your help in advance.
Dr. Jeff Lange
The JZX100 shifter should come through in the right spot for an A80. You'd want to use the front half of the propshaft from a JZZ30 and the rear half from the JZA80.
Trans mount use 12371-46030.
Trans to chassis bracket use 57255-24061 (same as JZA80 N/A).
Jeff
1 - 2 of 2 Posts
