1 - 11 of 11 Posts
Boost Junkie
A/F could possibly be affected.
You can run more boost as long as you have the fuel to support it.
The stock ecu will advance the timing more on race gas.
Steve
T88 YOU
i believe base timing on the motor is 23 degrees and it retards accordingly, however that number will never be seen. just a fact, the computer does NOT advance timing EVER, it will only retard timing, however the timing CAN be returned to its base if no knock is recorded.
1 - 11 of 11 Posts
