Basically I put my new HK$ Radiator cap on which is a 1.1 bar item as opposed to the 0.9 bar stocker.
Worked fine whilst driving, held pressure in top hose and still allowed coolant to pass into the overflow bottle.
However upon cooling down rather than sucking coolant back into the radiator from the overlfow bottle the top radiator hose has been sucked in. In my thinking this must mean the return valve on the radiator cap must be faulty. There was an awful lot of vacuum and had to really apply alot of force to prise the cap off. I guess I know that my cooling system is completely sealed!
So the main question is seeing as its a higher pressure cap does the return valve also need higher pressure ( I would have thought not) Now it is definately the right cap, there are only two types for Toyotas and the wrong ones do not fit at al and if you forced it on do not hold any pressure at all whilst driving.
I am shying away from pointing at the overflow setup being at fault as it work fine right up until I put this cap on
