1 - 3 of 3 Posts
Will the factory radio from a 98-00 Camry plug into the harness in a Mk3 (1989, no big stereo), or does the Camry radio use an external amp? Want to get rid of the cheesy looking aftermarket unit for a more stock look, and the 98-00 Camry units are cheap and plentiful..
it depends.
if fujitsu ten (they used to make the Eclipse line of head unit) built them then yes it will drop right in. Now way to tell though!
That is what I have in my car. Like you said you can find them anywhere.
Most fujitsu ten pre 2000 will work. High end stuff from later on with the external amp wont because power is not being supplied properly
1 - 3 of 3 Posts
