1 - 3 of 3 Posts
ƒ=1/2π(√k/m)
Well this sucks. :)
I had pulled all my IC pipes off to flare all the ends for a better coupler seal, then put them all back on.
Drive the car, and am getting sporadic AFR's.... just as if the AFM took a poo.
Pull the codes and got 24... air intake temp.
So does this mean the sensor died? (I disconnected it and plugged back in, didn't help)
It is the original one from Toyota, so I guess I'll replace it and see what happens.
Ever happen to you?
Fish tacos
Yes, the contacts were dirty and not touching eachother, took some electro-patrs cleaner and ziptied it together.
Works up to this day.
ƒ=1/2π(√k/m)
maybe I'll use some rubbing alcohol to clean the pins and plug... try again.
Sucks. :(
1 - 3 of 3 Posts
