1 - 12 of 12 Posts
· 2JZ-Phantom
Hey guys, today when I boosted my car and then stopped abruptly in third gear the car started to clatter. When I come off the clutch pedal in between shifting gears or when I brake there is a grinding, rattling sound. Does this sound familiar? I am running stock fuel and compression at 7 psi, other then that the car runs fine and drives fine. Please help, thanks.
· 2JZ-Phantom
It sounds like it is coming from the tranny and the front brakes. When I brake the sounds comes from the front brake area and after the shift and let off the clutch the sounds comes back briefly. Hope this helps.
did you check the bolts connecting the dp to the exhuast. sometimes they torque and loosen up and tend to knock against the pipe and makes that sound. thats the only think i can think of since you said you dont have anymore cats.
1 - 12 of 12 Posts
