1 - 10 of 10 Posts
No, ...It was NEVER NA!!!
Im about to put my stall converter in. I read, while searching through threads on the subject, that you need new bolts before installing.
Is this right? Can I not re-use the same bolts? They look good to me. If not, do I need some special bolts, or something?
You can probably get by with cleaning them and reapplying threadlocker.
Is this a PI converter? It should come with special bolts and I don't recall them being TTY.
I bought a used trans, and converter, ....so I dont have the bolts. I was just going to reuse the ones from the stock converter.
But is it a stock converter?? If it's a PI, you'll need bolts with a shorter head....
Yes, its a PI! Shorter heads? Why is that?
Because the converter is a bit thicker than stock. Ring up PI. They're pretty good about sending out bolts quickly. They even sent mine for free....
Discussion Starter #9
1 - 10 of 10 Posts
