1 - 15 of 15 Posts
I’ve been using redline shock proof heavy for years in my stock 6 speed dif.
  • Like
Reactions: Wreckless
From the land down under
Redline 75W-90 here.
Ive always stayed away from the shockproof stuff as have read varied reports on suitability to various seals and synchros, so prefer to stick to the plain stuff :)
My small 200mm rear takes 1.65 litres, but I imagine the 220mm may take slightly more. Check the TSRM to confirm first :)
that is true with redline fluid in the v160 not the diff
  • Like
I turn my own wrenches!
Same, always used Redline without issue.
Boost Junkie
1.8quarts. Use the Mobil 1 stuff you can get at any parts store. 75w90.
Steve
2007 FSAE World Champion
The 220mm Rear diff capacity is 1.43 US Quarts.
Smith & Wesson Member
Using this with my 6 speed TRD diff for 12 years - Absolutely no issues
  • Like
Super Moderator
The Redline Shockproof heavy is pretty damn ideal for the factory Torsen LSD. The Mobil 1 75w90 works fine too, but if you're really beating on the car from a dig or pushing more than 600whp through it, I'd go with the Redline Shockproof Heavy and I'd also budget for a proper clutch type LSD to replace the Torsen.
If you're below 500whp and mostly just cruising around and ripping it on the highway in street tires, you're not going to see much difference in LSD performance. I've always felt the Redline Shockproof made the factory Torsen LSD behave a bit more consistently but I cannot offer any empirical evidence of that.
96 JDM TT 6sp
Motul 90 PA has worked well for me over the years with a 220mm diff. Gears are in good condition now after 40,000km of 'spirited driving'. OS LSD install now.
1 - 15 of 15 Posts
