1 - 10 of 10 Posts
REVTECHRACING.COM
curt im guess im gonna need the oil cooler 15710-46020 OIL COOLER LIST 465.96 COST 344.56 since i had a melted piston during my rebuild.
and you mentioned in your sticky that a rebuild will also need 90402-16015 OIL PRESSURE SWITCH ADAPTER LIST 7.95 COST 5.88 so add this too.
dont know what this is but add this too if its is needed 00295-00103 FIPG PAN SEALER LIST 12.78 COST 9.36 EA X 2
i have this set you sent me but dont know if it has a rear main seal in it and am i missing anything else for the rebuild that is mandatory?04112-46094 Head Set Complete List 317.10 Cost 234.49
here is the block#4521334 crank#110011 and which # off the rod caps? there is a single digit on the top of the rods and a 2 letter with a # on the side and a 2 digit on the other side of the rod caps. which do i need to give you to order the main/rod bearings correctly.? also i gonna use the eagle rods that are stock spec.
thanks. and the name was william renkart in nj to look up my info on the previous orders on this rebuild.
If you need main and rod bearings, I'll need this info:
The 7 numbers printed on the block behind the oil pump.
The 7 numbers printed on the counter weight of the crank.
The 6 numbers printed on the opposite end of the crank on the counter weight.
The number printed on each rod cap [1,2 or 3]
REVTECHRACING.COM
block# 4521334 crank#110011 rod caps[top#] 1-3-3-3-3-3 rod cap side# 1-2-2-2-2-1 there is also a 2 digit # on the other side of rod caps. 39 appears on all of them. i need these and all of the above mentioned . will there be an issue w/ the rod bearings on the eagle rods?they are stock replacements. if not ship it all out.thanks curt.
I still need the 6 digit number on the crank.
IE:
front of block: 4521334
crank : 110011
crank : xxxxxxx [ 7 numbers ] I need these numbers!!!!!
rods: 122221
I also need the inside diameter of the eagle rods { big end]
I also might need the outside diameter of the rod journals on the crank.
And your name and shipping info.
REVTECHRACING.COM
4234323 and the letter j was near it. big end eagles 2.1665 inches or 55.029 metric inside #. crank was not touched just polished.
Ship to
William Renkart/Adam Miller
c/o Ziegler Chemical
600 Prospect Ave
Piscataway, NJ 08854
732-752-4111
Do you still have credit card information on file? If not i can call you with the information.
REVTECHRACING.COM
thank you sir.... can it be next day shipped or 2 day? i need it by sat..
1 - 10 of 10 Posts
