MDoe8 said:How big of a difference will i be able to feel? I did this and i cant feel a difference aso im thinking i did it wrong. I cut the two wires in half, extened each end into the switch and grounded it. I believe thats all i have to do?
Mike
Here's my half-article on TTC. Hope it helps.MDoe8 said:I attached a picture of what i dont understand. I understand the top four parts on the switch but are the bottom ones ground wires?
also, what should i look for when buying a switch?
Use the grounds on the wiring harness. It's that simple.bahraini_zupra said:hey guys .
got qusiton here the grounds wire where should they attached to ? battrie or the body ?
thanks
