1 - 2 of 2 Posts
I apologize ahead of time if this has been asked b4.
What are the technical differences between GE and GTE engines. Suprastore mentions head bolt pattern differences and clearances. Do they use the same crank, piistons, etc. Is the head completely different change compression.
Any help would be apprciated.
King of the NA-T's
The heads are quite a bit different, altho the cams are basically identical. pistons are different. No oil squirters on the n/a block. Different oil pumps. distributor drive on the na.
1 - 2 of 2 Posts
