1 - 20 of 21 Posts
Sorry to bring back old topic.
Are the front and rear bumper support designed for 5mhp only?
What You Know About That
i think he's asking if the bumper supprts are only designed to protect against accidents up to 5mph only. Jason is trying to remove some weight off of his car so he wants to remove these but there was an old thread were everyone was divided on their usefulness. Am I right Jason?
100% correct, thanks a lot :bigthumb:
i was rear emded at 53 mph, the rear support car bent like a noodle, looked like < after the accident. i removed my front one becaus ei had to so my bumper would fit so.. the rear didnt help much, and the front is basically useless if youre goin above 45, wont prevent much, but then again it isnt even that heavy......
Lagmeister
Urban Customs said:
those supports are more important then you guys think. if you take them off your car will flex more. there like a front strut bar basically also.
I agree with this and still believe the car is better off with them on for this reason, along with also being safer. I know they obviously would flex and bend in an impact, but if they didn't, what else would absorb the blow? Some energy displaced in an impact through these supports is better than none at all.
painted cf hood advocate
Even if the front bumper support is only designed for a minimum of 5 mph impact, it would not make sense for me to remove it considering that it is made out of aluminum. The weight savings for a car that will be driven on the street simply does not make sense.
Discussion Starter · #17 ·
NCSUpra said:
The front only weighs like 5 lbs. The rear i dont know about
Damn that is light.
If they weight 60lbs total and there are minimal side effects, no body flex, it might be worth it.
But for 5lbs, definitely not.
I have heard people replacing the heavier rear bumper support with the front bumper support.
NA-T member
I got another question, but its kind of off topic.
Ive pulled off all the body panel that I can; except for the rear quarter panels. I know there just tach welded on there. Does any body have a pic of just the frame, with the rear quarter panels removed.
1 - 20 of 21 Posts
