1 - 3 of 3 Posts
Has anyone else had this problem? I just replaced the rear brake pads and rotors with all Toyota parts. The car squeeks only when i step on the brakes while backing up. I just changed the brakes and the rotors. It does not squeak when going forward. Does anyone know what can be causing this problem? or is it common on the SUpra???
Supra TT Senior
Yes it's pretty common. Some people have had success with putting anti-squeal fluid/gel on the pads.
Did you get and install an anti-squeal shim?
1 - 3 of 3 Posts
