Anyone here have any tips on removing the rear bumper. I know someone had the same problem as I where the screw snapped off the little piece behind where the rear license plate attaches. I have the new brackets, but can't figure out if Im going to need new pieces to attach to, it appears my entire bracket is spinning behind the bumper. With the screw seized in it.. Am I going to need a bodyshop to reattach these?
The bumper has about 4-5 plastic push screws on the top (between the tailsights) and on the bottom. Remove those and the pushpins that lock the sides will pop out.
Chillen at the Holidae In
you want to get the ones off on the plate frame and then the top first. I found it easy to take the tailights off. Although i never tried it the other way, but in anycase that is my 2 cents.
steve
HKS T04Z & Vpro Equipped
the rear bumber was a pain in the ass. there are push pins and screws behind the taillights and also you might want to try to take off the exhaust to get to the side push screws. took me forever.
