What is the problem and what needs to be replaced?
Rear end sloppy moving left and right. Only happens under Excelleratio. Rear of car immediately feels like it sloshes to the right then to the left as power in the Open diff transfers.
Happening on 93 sc300 NA -6spd. (Miles 245K) Noticable everytime you hit the gas semi hard. Rear of car immediately feels like it sloshes to the left then back right, side to side the rear wheel must still be going straight. Only evens out when you let off the gas. Happens at low speeds and highs even scarier.
History Suspension and Drivetrain work:
-All 18 oem suspension bushings replaced with Diazen poly bushings. Front, back, lower, upper, sways.
-Tein flex Coilover.
-Diff (4.27 auto no LSD) drained 300 miles ago before problem. replaced with oem recommended 80-90diff fluid. no gray liquid or shavings.
-Single solid drive shaft from 6spd to custom diff adapter.
-Alignment done 300miles ago
When first installed 6spd this problem didn't occur it progressively started happening until really bad right now.
What is the problem and what needs to be replaced? What are the signs of axels/joints going out? Could it be the diff pumkin bushings wore out front or rear. wouldn't think they would cause this much flex more wheel hop if anything.
what kind of tests can I run to find out the problem?
Na-t comming next month so need to solve this before even more power than stock.
Everybodies Input is appreciated!!
