1993 Toyota Supra SZ (5 Speed)
Hey Supra fam,
This might seem strange to some, but I really like the look of the rear side markers on the Supra. I have a '93 JDM Supra which does not have the rear side markers. I also have a S2 front bumper with the front side markers, so I would prefer it to match.
The thing is, I dont want to just pick a spot and cut a hole into the rear, so I was hoping someone with a Supra that has side markers could help me out on the measurements.
Essentially, I'm after the measurements on the photo attached in MM if possible.
  • The green line is the distance from the center of the rear screw to the rear bumper seam.
  • The yellow line is the distance from the center of the rear screw to the bottom where it meets the black trim peice.
  • The red line is from the center of the front screw to the bottom where it meets the black trim peice.
the red and yellow measurements need to be parallel with the rear bumper vertical seam, that way I can insure that I'm measuring it the exact same way for accuracy
If anyone could help with this, you will be an absolute hero. Thank you all!
Tire Wheel Car Vehicle Automotive tail & brake light
