6.5" Just pop the grille off with a screw driver not scratching the plastic. Three screws and the speakers come out. The factory uses a little glue, so a flat screw driver sometimes helps. You don't need to remove the interior trim unless your new speakers do not fit the factory box. Then you would have to remove everything to do what is needed.
