I couldn't find too much information about this subject but I was wondering if rebuilding a 7MGE motor using aftermarket internals specified for the 7MGTE who be a problem. I guess I would essentially be using only the block, head and intake, and crank. I'm guessing the cranks are different though and I would need a turbo one. The reason I ask is because I have my old 7MGE and almost every Turbo part I would need to go NA-T, lying around and was thinking since you can boost the stock NA, why wouldn't you be able to rebuild it to turbo specs and run it to the extent of a Turbo motor instead of just throwing the turbo on it. Is there anything special I need to be aware of before going through this? Thanks for any info.
Tim
Tim
