1 - 13 of 13 Posts
Hey,
I'll have 3 amps in my setup. Do I just split the remote amp turnon wire into 3 seperate wires and run one into each amp? Or do I need to daisy-chain the one wire from one amp to the next?
- Andy
put a female spade connector at the end of your lead back from the head unit... then take a male and put four female ended wires all into so it looks like a pitchfork... that way if you get rid of an amp you can just leave the covered female ends there or take the fork out to easily remove the whole wire
brianb said:
I have 4 remote turn ons connected with one signal wire from the headunit. My 5 channel amp, capacitor voltage display, bass cube, and line adapter. No problems here.
Brian
That makes no sence at all. Caps don't need remote turn on. Most of the time more then 3 amps will work off the remote turnon wire but there are instances when they won't. I would use relay just to make sure.
The cap won't, but the display would.
It does depend on the amps, as to how many you can turn on with the remote lead, and other accessories that you have connected.
At one time, I was running 4 12V fans, 2 amps, a couple of displays and an RTA using the remote turn-on lead. Yes, there I used a relay, because the fans alone exceeded the recommended current max from my HU. Now, I don't have the fans, the displays, or the RTA. So I got rid of the relay, as it was just another layer of complication that I didn't need.
Ok, ok, maybe 500rwhp!!!
I guess you weren't the best reader in your class?
I said that I used it for my 'capacitor voltage display,' and YES my cap' needs a remote turn on.
Maybe if you brushed up on your reading AND comprehension skills, future posts will make more sense to you. Your overall quality of life would improve as well.
That is all.
1 - 13 of 13 Posts
