1 - 7 of 7 Posts
Administrator
Removal or disabling of the system? I'm guessing there might be some fuses you could pull that would disable the system. Why would you want to physically remove it?
Steve T. (weight loss junkie but ABS lover)
I think he means REMOVE. Look at the Titan car, all that brake stuff in the back corners of the engine compartment are gone.
The one cool thing is with the ABS on the passenger side gone, you can run a side fender exit race exhaust. Ever seen Chris Chow's 8 second twin turbo V8 GN? He's got duals. ;)
Administrator
I suppose there is no "simple solution" to removing it then...just a lot of stuff to remove and careful examination of the factory service manual and electrical manual to make sure you do it correctly. You might even call Titan! :)
Steve T.
1 - 7 of 7 Posts
