Finally had some time and manged to get that wheel knuckle/hub off. Those tools above worked great! Only question I have is how much play should the hub have? After taking it to a local mechanic, I noticed the turns on the hub are a bit harsh or hard to spin (unlike the driver's front side). I also notice a weird rubbing sound as I spin the hub, is this normal since it's a new bearing and seal? How can I know if the pressing of the bearing and everything else was done correct? The mechanic said theirs basically a one way in and out installation, and that here is no way it can be installed wrong :doh: . Anyway, while putting back one of the below arms that connect to the knuckle I noticed one of those rubber black bushings has tan grease coming out from where I tighten the nut/bolt. I hope I did not tighten it to much. I hope it's jut me seeing sh*t. Thanks in advance!
