1 - 9 of 9 Posts
I removed the A/C setup in my Supra and decided to take out the compressor as well. What drivebelt would I run now without that?
would you happen to know what belt size is needed for removal of both A/C and Power Steering?
GATES K060390 should work for P/S and A/C delete.
Just route it around the alternator, water pump, tensioner, and crank pulley in one simple loop.
Actually, when I removed the A/C compressor, there's a bracket attached to it at the top for the Power Steering. I cant mount the PS without using that bracket and it is attached to the compressor so I cant take it off. Even with it off, there is only one bolt that holds up the bracket. The rest mounts on the compressor...so what do people do when they remove the A/C, but want to keep the PS???
Well, the PS has to mount to something...and its that bracket. It's like attached to the AC compressor...
Can someone post some good pics, im curious to know how the a/c delete is done with a different drivebelt.
8 Second 6spd
NAPA part # for both A/C and PS delete: NBH25060390 (1008mm)
1 - 9 of 9 Posts
