Yeah, so my "JDM 7MGTE" ain't so JDM...turns out it's actually USDM (I didn't know enough about Toyota motors when I bought the car)...so anyways, since I won't pass emissions anyways (no cat) I figured I might as well remove the restrictive POS...what all do I have to do?
take the cooler off, other wise you still have a huge pocket of heat on the back of the head. just make a plate for where it goes into the cooler, you'll see what to make once you take it off. you'll need a plate for the intake chamber too, then re-route some vacume lines
You might pass visual emisions, anyway I wouldnt recomend doing that if you want to drive the car without getting fined.
But if youre trying to get rid of it completely remove the cooler in the back of the head, use block of plate to cover the hole, and the holes on the intake manifolds there are couple there.
And there is about 6156461684 of these posts hanging on the board search and you shall get all kinds of results even with awesome pics
If your engine has the EGR system it does not necessary mean that its not a JDM engine. The previous owner of the car might've installed the system to comply with the emissions regulations.
Kinda off topic, but a good way to know if your engine is a JDM one or not would be inspecting the metal coolant pipe on the back of the head and how its connected to the heater core. Jdm cars had the heater core return hose going into the metal pipe on the passenger side (as opposed to driver's side on USDM engines).
I would think that if you dont pass your inspection the information goes to the bmv or if cops see you smogging they can ticket you. I can already smell your exhaust fumes
In different state different laws.
Just do what every other self respecting government hating car enthusiast does and pay to get a fake emissions. Its like 150 or 200$ for one and then you say fu to the stupid emissions control
The EGR is not restrictive! The only reason to remove the EGR system is if you remove the cooler plate off the back of the head which eliminates heat from around the number 6 hole, otherwise you're not accomplishing anything. You pretty much need to have the engine out of the car to do this..............now go do a search for more info!
Yea but it sure as hell does clear out alot of space in that area! Removing the EGR and Cruise Control allows for easy access to that top starter bolt and even the knock sensor in the same area.
Hey guys my names triz
I’m looking to buy a 1989 Toyota Supra turbo 155k (automatic..... I know I know, but I can’t find a 5 speed not even N/A my plan is to do a 5 speed swap myself)
I was hoping for some help I don’t exactly know what I should be looking for, and I was hoping you guys could...
Hey all, I'm repairing my harness and I'm trying to figure out which connectors I need for the various sensors on the thermostat housing; mainly the two A/C water temp. sensors (light green/red and blue/white wires). If anyone can snap me a quick pic I would appreciate it MUCHO.
I am looking to sell my build I have, the car currently has 135,700 on the rust free 1989 Targa Top MK3 body with BC coil overs. Clean and clear Title, Fully interior/insurance street/race car. Dark blue cloth interior, no rips or tears no major stains.
THE BUILD HAS LESS THAN 1500 MILES AND THE...
I'm getting into my first Supra, a Mk3 Supra, and this might be a really dumb question, but nobody could answer it better than on here. I know that Subaru has Cobb as its main aftermarket brand(just an example), and I was wondering what brands I should try to look for when I'm buying aftermarket...
