1 - 7 of 7 Posts
S
How do I get into the left button array in the dash? What do I take off? Are there any diagrams? I want to remove the foglight switch
S
Discussion Starter #2
AGlobalThreat mentioned a B+ spot in the diagnostic box.. does anyone have a picture/diagram of this?
I am wiring an electric fan.
FIX-R upper
there is one screw under the panal... then it just pops off
HA HA HA HA.. sorry, its just funny to me that you cant take it off. Good Luck!
S
my and a buddy looked for such a screw.. and couldn't find it.. I will take a look after work
Madd Tyte JDM yo ®
well, look at the trim panel that the buttons/coin holders are sitting in, then follow that panel as it curves under. there is a SINGLE hole that SHOULD have a single phillips screw in it. if its NOT there, then the panel is only clipped in. then, just pull it back and itll pop out. once you get this panel out, you have to obviously remove the connectors for the fog light and whatever else is there. the fog light switch should just have 2 tabs that you compress and it comes right out.
yep, it's just clipped in after that screw is removed, just pull...
1 - 7 of 7 Posts
