Make sure you know exactly where it's leaking before you start tearing it apart. Maybe it's your oil filter thats loose? Use brake cleaner and blast the pan(s) clean, should dry on it's own.....then run it while on the lift or something (be careful) and watch as the leak develops.
If it's the oil pan(s), you have to slightly jack up the engine (unbolt motor mounts), in order to remove them. Be careful as everything will go up with the engine, like fan, harness, etc.....if you jack it up too much you might break or rip something apart.
Good luck.
Good luck.
