1 - 10 of 10 Posts
Shaq who?
I'm removing my Auto Tranny from my 1jz to mate up the R154. What is the best way to take off the torque converter? Big Flathead? Bar? Anyone?
there are 6 bolts that hold the torque converter to the flex plate. moving the flywheel is very easy, just put a ratchet on the crank pulley bolt and turn it after you've loosened a bolt.
Acting my age
And in case you havent noticed.. there is a big rubber cap on the underside of the bulkhead that the tranny mounts to. Remove it and you have access to the flexplate/converter bolts.
Shaq who?
Discussion Starter #6
Thanks Matt, I didn't even see that! Well I got off the TC but how do I remove the flywheel? I will do a search now and probably find the answer but someone feel free to answer me.
just unbolt the 8 14mm bolts that hold it onto the crankshaft. you do have the transmission removed already, right?
Shaq who?
Discussion Starter #8
The flywheel turns when I try to crank it and I tried putting a prybar in the holes to keep it fromm moving but that didn't work
Your Neighborhood Pikey
Get a buddy to back up the crank with a 22mm on the crank pulley up front. If you don't have a buddy, get a breaker bar long enough to brace it against the frame rail so it will hit it when you turn on the flywheel bolts.
1 - 10 of 10 Posts
