I'm going to remove the trac pump assembly over the weekend. The trac pump has a brake line going to the ABS assembly on the passenger side that will removed and plugged. When I remove that line from the ABS, it will let air get into the ABS system. To get rid of the air, do I simply bleed the brakes from all four corners? Or is there a special way to bleed air from the ABS assembly? Thanks.
