1 - 11 of 11 Posts
Since everyone is attempting to convert their MK4"s from AFM to speed density I was wondering if anyone has ever considered using the Power FC? The reason that I ask this is because the Jap spec Supra runs a MAP sensor vice the US AFM. By utilizing the JDM you would be converting to speed density and have ignition/ fuel adjustability via the commander, so you wouldn't need to haul around the lap top.
Before the flamming starts I will start off saying that I am aware that the JDM Supra and US model Injectors are of both different impediances and sizes. Adding a resistor to the injector harness will solve the impediance problem, and you can create a fuel curve via the commander.
I have compared the wiring diagrams from the US version to the JAP version for compatability for the AEM EMS. There was a total of 6 different wires between the 2. They are for the MAP sensor (need to add), MAF sensor (would need to remove), and the #2 exhaust 02 sensor (OBD1 vs OBDII).
This set up should allow the average racer who doesnt want to go through the hassle of learning the stand alone systems, but yet have controlability as needed.
I have never tried this conversion, but it seems that it would work and theroy, and provide basic users access to Fuel, Ignition, and convert to speed density at the same time.
Currently e-manage, S-AFC (I & II), nor MAP ECU can do all of these in 1 box!! Please, I'm not an Apexi dealer, and I don't care if you ever do this mod, just trying to help.
If the Aussies ever create the data logger box for the MK4 Supra's, AEM might have some competition with their plug and play, base map included stand alone system. Because with the data logger for Apexi you can have 100% controlability as you would with any EMS.
This may help you guys out, because i live in Japan. Therefore, my car is already speed density, but I intend on using the AEM EMS for I want full tuning ability..
Would the Power FC have any advantage over AEM EMS??
Lets go Nets
what about the HKS FCon VPro, Jap-sec supra's have them?
Brett
brett, Yes there are JDM Supra's running the HKS V-Pro, but this will not convert your car to speed density and you would have to use the JDM ECU, which took my 6 months to get an extra one and I live in Japan.
The only advantage over the AEM that I could see is that you can program the Apexi via the commander instead of the lap top. This would be better for the ametuer tuners, and eliminating the stupid AFM would be worth it alone.. VPC and Map ECU couldn't even dream of doing ignition timming..
Lets go Nets
baf32 said:
thats a first on ebay for me to see ;)
looks interesting.
$1,200 not bad, you think itll work?
Brett
1 - 11 of 11 Posts
