1 - 2 of 2 Posts
92 TURBO
HELP! Are any of the wiring harness connector plugs available separately? I need both ends for the cps, ( the cps end is a gray 4 wire with "11122" on it), no numbers on the mating gray engine harness end with the lock tab (which broke off as soon as you press it)?
Also, the gray 2 wire plug for temp. sender with "10735- 11061" stamped on it.
All these plastic connector plugs release tabs break off as soon as you attempt to disconnect them, it's so fu#kin frustrating.
Thanks, mike
The 11122 connector is $ 4.78 and the other side of the harness is also $4.78
not sure about the temp sender plug....call me
Jeff
1-800-327-2087
1 - 2 of 2 Posts
