1 - 13 of 13 Posts
PlayBoy
i did a search but the search feature seems a little whacked.
Approximately how long will it take to remove and replace the stock twin turbos with another set of stock twin turbos?
4 hours? 8 hours?
Assuming it's being done by a mechanic that hasn't worked on a supra before.
infernoo, thanks a lot for those links, saved me the trouble of hunting them down and I'm needing them now too.
are you sure you need to replace both? I say that because I had the front turbo go out and was able to replace it quite quickly leaving alot of stuff in the car. I did a pretty nice writeup on the replacement too. Just search under my name.
SupraBoy, I'm doing mine this weekend. Good luck with yours...
Boost4fun
Agree to that. The first time is PITA!:( The engine bay around the stockers is kinda designed that narrow spaced for like japanese mini hands;)
If I remember it correctly it took me even longer than 10 hours to do the whole job. But I wasn´t doing it in a hurry.
Gerd
No Ego or Arrogance!!!!!!
Me too replace them,it took me about 10 to 12 hours working a little each day about 4 hour a day for 3 days they are some stuborn nuts that you have to spray.Its very tight in there I have thick forearms and end up with some scratches very fun.
So you did a writeup on replacing just the #1? Was it MUCH easier? You werent making any boost at all on the #1 or spooling slow or what were the symptoms?
man i got half way into it then just had a friend finish the job at his shop. GL with it though it helps to have small hands i posted some pics a while back you might have seen them in your search
1 - 13 of 13 Posts
