TRACK CAR
After dialing in the overall rideheight with the new CCWs I took the car over to get corner balanced and aligned. Here are the final numbers with 205lb driver
1044 963
859 761
Cross weights came out to be 1822/1805 so I was pretty happy to get it that close. The car ended up weighing 3420 with a half tank, so that wasn't too bad for minor weight savings. Most of the heights cam out to be right at 26" measured from the ground to the center of the fender.
They had a hard time hitting the caster that I wanted because of my camber request, but here are the results.
Front
Camber -1.6
Toe 0
Caster 3.5
Rear
Camber -1.5
Toe 1mm in
After taking some corners at speed I have to say that this setup is very nasty. The car seems to be a lot more neutral on throttle, and overall just a lot more predictable. The best part about it is the whole balancing and alignment only cost $195!! I couldn't believe it when he quote me that price but the best part is they knew what they were doing too. I have a couple of track days coming up so I will let you guys know how it really feels on the track.
Mike
Generally 5* of caster S/B possible, but corner weights look good. What tires are you running? I assume these are 17"? I should have my car back from a full repaint in about two weeks, My RX7 Race car blew a BL-PT67 with zero miles on the dyno, so I'll be tracking the Supra til the race car is done. I'll be running 305-35-18/265-35-18 RA1s.Carl
