·At my current bpu level, it seems pointless to rev beyond the factory redline. What abt you guys with the t78 or to4r. How much have you raised the rev limit to and hows the pulling power beyond factory limits?
Thanks.
Thanks.
imo... I wouldnt recommend raising the rev limit, seems alot of guys that raise the rev limit w/ big turbo's blow their front main crank case seal very easily.ianong said:At my current bpu level, it seems pointless to rev beyond the factory redline. What abt you guys with the t78 or to4r. How much have you raised the rev limit to and hows the pulling power beyond factory limits?
Thanks.
what can be prevented?? Big single turbo does not give you full boost until 5k and if you don't up your rev limiter the you got to shift at 6.5k.nils said:
take care,
nils
Well, if you catch it before all oil dumps out you wont have to replace anything but a new seal. Check out the link below:supra178 said:
once if your front main crank case seal are blown then what do you need to replace? head?? thanks.
I read the article at http://www.to4r.com/techcrankseal.html Nils, and I was wondering if anyone _has_ enlarged the pressure relief valve return hole and solved the problem...?nils said:
compliments of Lance W. =)
I'm curious... TIA.
There is a proposed solution at http://www.to4r.com/techcrankseal.htmlsupra178 said:it didn't provide any solutions??? does anyone have a solution for ths?
I have gone through a couple of crank seals already. I've talked to Jeff Watson from Jay Marks Toyota and he said that when he blew his crank seal, he enlarged the pressure relief valve on the oil pump. He has not blown the seal since. Of course, that does not mean that the mod worked since alot of people just replace the seal and haven't had a problem again. Maybe someone could test this mod out?quick said:
I'm curious... TIA.
