1 - 11 of 11 Posts
hey guys... i've a slight problem with my tranny...
forward's everything perfect... but REVERSE ... i just can go for ~1mph ... if i pull the pedal, RPM goes up, but no acc.
no noise... nothing... just a very very very slow acc ... max. 3mph...
what happened?
done... very ok ... ;(
Ludicrous speed! GO!
Pull tranny trouble codes yet?
nope ;(
no other ideas ?
0 to gas station in 5 sec
when the transmission on my camry went, reverse was the first to go, the rest of the gears went a week or two later.
Sounds like maybe the reverse wet clutch bit the dust or there's something stopping fluid from reaching it correctly.
what would jesus drift?
try to change the filter??
SUPRAF0RUMS TROLL
filters not gona do jack... if hes going fine in the foward gears ... it is his reverse clutch pack that has gone bad...
let me ask you something though matce... were you going reverse and popping it into drive real quick to do a big burnout?... thats the only thing that i can think of that would destroy your reverse clutch pack
Discussion Starter · #11 ·
nope ... no burnouts with R->D ... mhm... sounds like trannys gone ...
okay guys ... so i will destroy it completely and change *G*
no MT-swap .. i like AT :) ... but will have to upgrade i think :bigthumb:
thanks!
1 - 11 of 11 Posts
