1 - 3 of 3 Posts
F
Does the SP engineering single turbo kit fit Right hand drive JDM supras. I did some research on the forum and the answer from Larry from SP was, "he didnt know as he had never seen a RHD supra. :eek:
I tryed the HKS and Greddy kits on both RHD & LHD they fit normal ... you'll need to heat shield the brakes fluid tank in the RHD.
I assume all other kits will be the same.
(note: Larry is from (SP) Sound Performance and not SP Engineering they're 2 deferent shops .. both are great though :) )
Good luck bro
Salam
6Spd TT Aerotop
Yea you'll need to heat sheild the brake fluid in a RHD, I have the HKS T51R and first day I got it back, half way through the day my brakes went spungy and I could barely stop, with aftermarket Brembo F50 four pots. Turbo had boiled the brake fluid. Had a heat sheild made to go around the brake fluid and clutch fluid.
Dan.
1 - 3 of 3 Posts
