1 - 4 of 4 Posts
Hello,
Is the RMM downpipe full 3 inches all the way through? Or does it neck down at the flange?
Is the Tanabe Racing exhaust for a 93-98 MKIV full 3 inches or does it neck down to fit the stock cat? Also does the RMM downpipe and Tanabe exhaust bolt up together size wise?
I had a DSM and the apexi N1 exhaust came with a adapter to fit the stock cat the N1 or a GSX is full 3 inches all the way through so when you mated the N1 exhaust to the N1 down pipe you had a true 3 inch exhaust from turbo to tip.
Is that the same with a MKIV?
THANX
Discussion Starter · #2 ·
It looks like it necks down 1/4", but it only does that so you can use the factory flanges. :)
TROY
TROY,
Are you talking about the RMM down pipe or Tanabe exhaust?
Can anyone enlighten me on this?
THANX
1 - 4 of 4 Posts
