ok, so getting ready to rebuild my 7m here again.. gonna put new bearings in along with a brand new set of eagle rods and wiesco pistons.
now, i figured i would use the standard sizes for the main bearings because its gonna be stamped in there ready to go so i can order them and move on.
but the rod bearings are giving me some hassle... i assumed i could size the eagle rods with a micrometer, then measure the rod journal on the crank as well, to give me an accurate size of the bearing needed and order it from clevite. but a friend who does extremely reputable work was stating that the rods themselves should all come in the same sizes so getting a measurement from the rod isnt needed??? i would have assumed that needing both measurements would be nessesary because the eagle rods probably dont come in the same size as stock... since stock in the manual for the rods can be 3 different sizes (1,2,3 as stamped on the rod itself), match that with the block (0,1,2) and you get 5 different possible sizes of bearings...
am i missing something here? what is the way i should be getting the size of the bearings for this new set of rods? last thing i need is to rebuild this and have to tear it down 10 miles later because i screwed up 1 measurement.
thanks
thanks
