Does the Rod Millen Wing need any special modifications to fit on the car or does it just bolt in place? Also is there anything supplied with the wing to prevent the water leaking through?? Thanks.
Just bolts right in stock location. No mods need to be done. The stock wing has rubber gaskets that you can reuse with the RMM wing to prevent water leaking through.TRDSupraSE said:Does the Rod Millen Wing need any special modifications to fit on the car or does it just bolt in place? Also is there anything supplied with the wing to prevent the water leaking through?? Thanks.
