So I've ran into a little snag with my Roll Control installation. I've noticed that my brake master currently has 3 brake lines coming off of it, starting from closest to the booster:
1. Front Right
2. Front Left
3. Rears
my understanding is that i am to intercept front brake lines before they "Y". in my case this is not possible. would you guys:
1. plug one of the front ports on the master then install a length of brake line to the Roll control to the other port then"Y" off the roll control to send to either front brakes?
2. use both ports and install a "Y" and intercept for the roll control and then "Y" again?
3. other options? different "Roll Control" or "Line Lock" options?
i'm probably making this more complicated than it needs to be. any help with this would be very appreciated.
Residence1 I think That Break master Cylinder in the pic you provided was only offer on JDM Car if I am not mistaken. Can you please confirm if the car is a JDM Supra? From what I see in the pic you have a Non ABS master cylinder with 3 outlet ports.
Take a look at this thread #85 Response Link
yes it is a JDM car (supra). also your right it is a Non ABS master cylinder with 3 outlet ports. thanks for the link i'll check it out now.
No problem. Please keep me informed with your progress.
