1 - 11 of 11 Posts
I recently installed my afc and attempter the e-ttc. I stopped midway through my e-ttc and just wired them back to normal just because i wanted to. Now my idle is very rough. It sounds and feels like it is almost missing. I can rev it up and hold it at a certain rpm and it still sputters while up top. I dont know what it is and what the heck happened but it is pissing me off. Any input would be great
Mike
they are gapped at /032 i believe. I just replaced them recently. I checkd wiring fifty times, i reset ecu, i checkdd the afc settings, i made sure everything was plugged in, and i have no clue whats going on.
Mike
ugh! I need help!!
Sounds like its missing, its got a popping sound to it and the air/fuel gauge isnt working properly either. Anything!!!?? I need to get this running right!
Mike
Thats what I figured but i keep looking over that and they seemed fine. The thing i was worried about was the settings. It is on hot-wire in-12out-12in-1out-1. I guess this weekend i quadruple check everything. I need a freaking fields harness.
vampire? not familiar with the term. I sued the ones that you stick the two wire in and squish down the middle "blade" and then clip the cover over that.
Mike
Yes, brothers own Supras
LOL...thats a vampire tap. You splice into the existing wire without fully cutting it. Make sure those are crimped well. Alot of times people get taps that are too big for the wires. The blade doesnt fully cut throught the insulation so you get a bad connection.
1 - 11 of 11 Posts
