1 - 2 of 2 Posts
Has anyone got instructions for the RPS street 2 clutch install. We have installed the clutch and we are getting juddering through the clutch pedal when releasing the clutch pedal and the throw out bearing looks like it is vibrating. Which way does the clutch plate go? We cannot get any gears when the clutch is depressed.:(
i assume you were you able to bolt the clutch pack to the flywheel properly? if the clutch disk is installed backwards, you wont be able to bolt the pack onto the flywheel properly. have you also checked to make sure that your slave cylinder doesnt need bled? you could also call RPS....i wont go into any detail, but i was told by a well known aftermarket supra parts distributor that the clutch disk went in one way, i argued with them about it, said screw it, called RPS, and they confirmed for me my suspicion. i installed it the way i thought and it worked like a charm.
1 - 2 of 2 Posts
