I have an RPS stage 3 with a fidanza flywheel. as I went for a midnight drive I lost clucth pedal pressure, I thought I may be low on fluid and pulled over checked the levels to be ok. As the night progressed it got worse and worse.
I can shiftr comfortably by pressing the pedal 75% and I'm ok. If I press the pedal 100% to touch bottom I get a horrible noise and I can feel in the pedal as the clutch disk is slipping in idle.
My mechanic (ex-supra owner) tells he remebers that RPS had problems with their diaphragms back 6 or 7 years ago, but has not heard of anything since.
Has anyone had a similar problem or can think of this happening before?
Any recomendations? if this is a documented manufacturers defect do you think they will replace it or should I just write it off as a loss and get another?
