1 - 4 of 4 Posts
I've seen some RPS Stage 2 Clutches that comes with the RPS Pressure plates + OEM clutch disc and some that comes with the RPS Pressure plates + RPS Carbon Claw 6 puck disc. Which set would be better for around bpu+? also is changing all those throw out bearings, snap rings, etc really necessary???
I believe the six puck means it is the stage 3. I had the stage 2 for the last year+ and it just went out. It had good feel, and was very slippable. I just ordered the stage 3, so we will see how that goes. If you don't plan on going to a larger turbo I don't see any good reason to go for the stage 3 unless for some reason it lasts longer, but I doubt it.
From what I have been told it is a very good idea to replace all the bearing etc. If nothing else you must replace the flywheel bolts if you take them off! I have heard stories of people breaking the bolts off when they tried to reuse them.
1 - 4 of 4 Posts
