1 - 8 of 8 Posts
once i remove the fuel cap.. there's a lot of rust on the metal area..
how would i get rid of the rust???
i can't use a cleaner cuz it will get into my gas tank.
any suggestions?
thanks!
wire brush maybe?? if any DOES get in, the filter will get er
or if its not that bad get that crap called never dull, kinda like a s.o.s pad but not as abrasive
use navel jelly it will destroy the rust before your eyes and then wipe it away with a wet cloth.
No it is a pink jelly. You can find it at home depot in the paint section. The chemical reaction that it provides disintegrates rust and leaves the metal. But do not leave it there for hours..otherwise it'll turn the rust into a black crust like material that requires alot of scraping to remove. Get a wet towel..wipe it on that area..then get the navel jelly and carefully put it around there..then you wait like 5-10 mins and u'll see the rust is disappearing..then wipe it away with a wet towel. If some rust is left over..add some more and do the same. Hope that helps.
1 - 8 of 8 Posts
