1 - 4 of 4 Posts
JetFire
I would search but......................anyway who here is using a safcII on the soarer ecu. I had mine installed last nite car has PT61 with 440's. It's running pig rich and wasn't really responding to adjustments. I followed the install instructions from Apexi I will recheck all the connections. I have a Greddy BCC that's tapped into the same map in/out as the safcII also.
Project:: Reaper
you will need to make up the difference in the SAFC
so if your 440's are 25% larger then you need to take out 20-25% fuel, but seeing that you have a Single setup i would get it dyno tuned
RoastBeefCurtain Commando
Are you on a wideband, or are you assuming its pig rich?
What do you consider pig rich?
Is this at idle, full load? Both?
JetFire
I'm on wideband plus there was black smoke and it was eating a lot of gas turns out that my map sensor vaccum was loose. I'll reconnect the safcII this weekend.
1 - 4 of 4 Posts
