I've been reading that people's biggest complaint when going for high HP on the stock ECU and the SAFCII, is lack of timing control. I'm assuming there's not enough or too much timing. Why can't you just adjust the intake cam with a cam gear, and just play with the stock base timing? If you want more timing, just advance the cam, and if there is too much, retard it (*to a certain limit, you can't expect timing like you would get with a stand alone*)
Am I missing something here?
