1 - 20 of 414 Posts
Hi everyone,
This is probably going to be a long thread so sorry in advance. First off my name is Paul and this is my first supra I bought back in 09/12/07. The car was purchased from Mcgrath Lexus from a guy that worked there named Mark. At the time i was 18 (I know now i was to young when I bought it) not knowing when i bought the car it was in a accident. The car had 4 owners now before me with 112k Miles on it. The car was a 94 TT(single already) 6 speed targa Ren Red and from the outside it was in pretty good shape. End up picking the car up for 22k which i thought wasn’t bad at the time..
Over the past few years I really started learning about the car and enjoying it when i get the chance! Here in Michigan that that means only about 6 months a year. Some of the typical problems started showing like Clutch, Tires(car was never aligned properly) Valve stem seals among other things. Most of which I took care of just so i could keep enjoying the car and driving it.
This is my current progress with the tear down. I’m still not totally sure what my final plans are with the engine (Hopefully someone can help decided) but I’m just looking for a nice 700HP max streetcar that i'll just be able to enjoy and not worry about or have any problems with(Hopefully).
I’v been talking with Stefan (exvelocity) on restoring tips. He is VERY nice and VERY helpful when it comes to Supras.
As for the engine i plan on taking it to the guys at SP (Only way to go imo) to let them work the magic they do. As I've been talking with Reid through email on figuring out what will be best for me but hes a very busy guy and the emails can take awhile for him to get to.
Like i said im looking to run around 700HP on E85 with ProEFI and SP Torq monster kit..
Anyway onto the photos of the tear down.. Going to be lots of pic’s sorry but i'm trying to document stuff to.
As you can see the bumper has been replaced from the accident
Air blower did this..
Picked up a lip i started trimming
Used paint stripper to speed things up a little
Discussion Starter · #2 · (Edited)
Picked up some clear turn signals and started test fitting
had to fill a little bit of stuff.. i got carried away with the power washer..
Started fitting the lip
Had to let it sit in the sun to bend it over a little.
After sun.
Moved to the inside of the car to see what stuff could be clean up a little and reused.
arm rest after.
Started taking dash apart.. going to have to restore these.
As you can see my main dash pad is broken! :(
E Brake handle will have to be replaced.
Moved back onto the lip.
Had some crazy idea to get a little more air flow to the FMIC without fully removing the rebar
Started taking the fender off.. you can see its been replaced
Put some side caps in the lip
Cleaning up the fender..
The other fender was replaced also.
Found the upper rail had some.. lets just say some body filler in it..
Started getting into the doors to see what i would find..
Picked up a set of JDM power folding mirrors from a good guy Chris (2cars=4turbos) finally time to test fit.
Picked up a cheap wing on ebay… was a bad idea. lol
Discussion Starter · #6 · (Edited)
At this pointed i moved the car down to the pole barn to reallly start the fun. How she was looking.
Just to give a idea how much overlap the ebay wing had...A friend in Cali sold me his real wing so i bought his don’t worry!
stipped the door completly down and took it off along with the side vent
seals and headliner.
other door was just as bad..
Completely stripped and pulled off as well.
Started removing back bumper and taillights. As you can see this one has a crack.
Trunk plastics seen better days. The targa coming in and out does to much damage :(
Rear bumper cover was off and i found this wire. Anyone tell me what it is? Was just hanging.
Some sweet screw holes i need to fill
Clearly had a sound system at one point..
More trunk plastics that are all scratched up.
Some sweet wiring ..
Discussion Starter · #9 · (Edited)
Alarm
slowly..
Had to clear out the charcoal and abs
Pulled the heater core… gave me trouble..
Trying to figure out the wires..
Found the airbag line was rubbing under the passenger side fender..
New dash came in! :D
started taking the intercooler pipes off. pretty happy its not full of oil.. but ya..
You can see some of it is not.. well not right lol
Radiator
Fan has been replaced.
Discussion Starter · #12 · (Edited)
Started removing some of the lines.
Decided to test more cleaning products to try and match the new dash :)
Picked up a TRD bar to see if it would fit cuz of the damage.. Gotta love Curt! Cant find the pic but had to force the bar on..
Dirty gas tank.. was a BITCH to remove with the double sided tape haha
Started prepping for something to hold the engine..
Comes out sooo easy..
Discussion Starter · #13 · (Edited)
You cant see it here but the rear lift hook bent pulling it out! scary.
Found that the motor mounts weren't tight! O_O
Took the trans off
Motor needs some SP/Naber Racing love! By some i mean LOTS
Discussion Starter · #15 · (Edited)
Started pulling the Calipers to restore them.
Picked up a Sandblasting cabin.
Getting a feel for what i like.. Thinking black with chrome "Supra" logo without the sticker..
Veiw-1642 by rozeboom2012, on Flickr
Cleaning the rust and shit inside the cylinder right takes awhile..
Veiw-1651 by rozeboom2012, on Flickr
Veiw-1649 by rozeboom2012, on Flickr
And that's pretty much where i'm at right now.
JZA80
Looking good so far, love these kind of detailed builds.
What cleaning products did you use on the glove box lid? I need to do mine as well to match my new dash.
Discussion Starter · #17 ·
Blackfire interior protectant, ultima interior shampoo Gel and 1Z Einszett interior cleaners, Cockpit Premium and Plastic Deep Cleaner.
Hope that helps!
Detailed restoration indeed. Subscribed to see this beauty come back to life
1 - 20 of 414 Posts
