I want to convert my TT brakes to NA brakes for my drag setup. I am curious if the calipers and rotors from SC300 and SC400 will work and bolt right up? Thanks!
they are identical.Yes, the SC300/400 brakes can be mounted onto the MK4 Supra. I'm unsure if they are identical to the MK4 NA/JDM brakes though.
I've seen the bolts that hold the caliper halfs together have opposite ends depending on the years. i.e. on one you would need hex socket to remove the bolt, on another you would allan wrench socket.they are identical.
