well guys.....and gal.....fuck my life. well...motor is a fresh rebuild, first time i've gotten it started up and running decent (so i thought) since the rebuild. I had lots of attempted starts, enough to turn a brand new set of plugs PITCH BLACK, so i found out that was why it wasn't starting. I had an old pair of plugs laying around (i figured they'd be fine for startup) they are bosch platinums, i cleaned the dust off of them with carb cleaner and went for it. Bang! the car fires right up, but it has a knock every here and there....a very LOUD knock like rod screaming let me out knock, and then it will be steady for about 20 or so seconds then go back to the intermittantly knocking and then after a while of running go away completely. It is so random, dead quiet, then one here, one there, wait a while, then constant for a moment and then it goes away. This is very loud people...scary loud. The oil is full on the dipstick and is new as can be. he car maybe has 10 minutes of running time over the course of 3 days and 3 of that is the very short drive i have taken. I can't hear the knock from in the car (open 3 inch downpipe) but i can clear as day (when its fucking there at least) from in front of the car. Also the car acted like it wants to die upon reving, it gave me a code 31 (air flow meter) and a code 51, i know the 51 is from having the ac button on, because the tps is brand new and calibrated freshly. I replace my afm with another one and i have the exact same code. Jiggling the wiring does not matter at all. My main concern right now is the painful knocking sound on my brand new motor. JE's, eagles, clevites, arp's, mhg, the whole 9 yards. I adjusted the set the base and ignition timing perfect btw and it made no difference. Oil pressure is 46-50lbs at about 900-1100 rpm with shimmed pump, relocated filter, and rc7 fc cooler. the other day it was at about 20 but that was when it would barely stay running and it went up. I know the idle is high, but i just got it running still got those kinks to work out ya know? pulled the first 3 plug wires also and it made no difference.
__________________
__________________
